Convertible latch opens too slowly
Thanks all for the great threads on convertible systems and for simply a great forum.
I have gone through much of the advice to try and isolate my small challenge, top not opening.
- In the top up position; I topped up the reservoir with CHF 11s, I closed the top(top down) manually, I then tried to open the top and though the pump was running nothing happened.
- I then unscrewed the cover over the front mechanism to clean the latch and movable parts that secure the top in the down position. I then tried putting the top up(open) but nothing happened except I could hear the pump running. I released the pressure in the system and then helped along the the opening procedure by manually releasing the latch with the Allen key just far enough so that the pump would take over, and then it worked.
- So, by unlatching the mechanism with the A.key so that it opened the top a little, the pump was then able to open the top completely.
Here is my summary observation; fluid level is good, top opens with a little help but closes correctly and windows reset normally. It seems that there is less strength to release the latch for some reason even after I have lubricated the necessary parts.
Question; does anyone have a reason or thought why the opening of the latch is slow or not happening?
WTB[International]: Front suspension and fuel pump
xjtom
03-31-2016 04:16 PM
