Convertible not latched -Resolved
Picked up my “new” 2003 xk8 convertible today. During the prepurchase inspection the Pass side quarter window failed. it is now mid position. Tried to manually press window down but no go.
nice night so I lowered the top. I get a message in the message center that the “convertible not latched “ and a red light. The top appeared fully retracted so I assume this message is related to the position of the window. Also I noticed the top latch is still exposed and if I understand the owners manual this will retract when the top is completely lowered
window regulator replacement is on the “to do” list
any short term fixes till I get the regulator fixed?
Randy
Randy
Received 4,341 Likes
the convertible not latched is the result of the latch mechanism not being stowed - when putting the top down simply make sure to hold the button until the latch goes into the stowed position.
As for the window - you can remove the relay and jumper to get the window to close - check the how to's in the stickies at the top of the XK8/R forum
m2zoo4u (04-25-2023)
Kevinhj
02-28-2014 07:05 PM
