Convertible Owners How Many Of You Put The Tonneau Cover On While Riding Topless ?
#63
#64
#65
My only experience with convertible tops prior to the XK8 was with our BMW Z3. It had a manual top and no tonneau cover, and it only took about 5 seconds to drop the top. Putting it back up took about the same amount of time because I have long arms and I could just reach back and grab it. I have to admit I'm a little disappointed with the difficulty of putting the XK8's top back up. I have to actually pop the trunk, get out of the car, remove the cover, roll it up, put it in the trunk, and close the trunk before I can even hit the button to put the top up. And then it's wait... wait... wait... for the top to finally finish it's cycle.
I tried driving with the tonneau cover off one time, but the head liner was just flapping in the wind driving me crazy. I had to stop and put it on.
#66
Hey Sam--if it's taking too long to close make sure you don't have any hydraulic issues.
I have mixed feelings about the manual tonneau situation. On the one hand, it has an "authentic" British sport car feel to it but on the other, it does result in a lot more futzing around. Last week the weather here in SoCal was perfect for top down so I opened the top and took the time to install the tonneau. When I left for work the other day the weather had turned a bit and it was gray and misty outside but my commute is only about 10-15 minutes (for 4 miles). I knew it would be sunny later in the day so did not want to bother removing the tonneau and putting the top up so I just proceeded with the top down (against the warnings of my wife, who, by the way is always right!). Sure enough the mist turned into a drizzle but I did not want to bother pulling over to remove the tonneau and closing the top. Luckily, I made it to work without really getting wet. But if this had been one of the newer convertibles with built-in tonneau, I certainly would have hit the close button.
Doug
Doug
#67
#68
No... I don't think I have a hydraulic issues. It's just not nearly as fast as manually pulling up my Z3 top. But now you have me wondering how long the whole cycle should take. I think I'll time it and start a thread to compare cycle times.
#69
It takes me less than a minute to put the cover on! Who doesn't have a minute!! I am probably one of the laziest people on earth, but I still take the effort to put it on. Caught in the rain, just pop the boot lid sling it into the back seat, close the lid and raise the top. Less than a minute!!
#70
#71
I do not think that Jaguar sells these as separate parts.
Try emailing Charles Whitney (clwcruiseco@yahoo.com) who manufactures his own covers. He repaced my tabs when they were lost at a nominal cost (albeit I did buy a cover from him some time ago previously).
#72
I guess you can just use some appropriately sized dowel.
#74
#75
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
I always use the cover. It looks better, it keeps the top liner clean, it keeps dirt off the inside liner. It only takes a moment to put it on. If someone wanted to use the car but couldn't take the time to put it on, I'd tell them to forget using the car. (wife, girlfriend, etc.) I always tuck the flap in behind the seat and have never had any lifting problems. With the trunk portion captured, the snaps in place, and the front tucked down, it should be good. I will add the velcro to mine, however, as it sounds like a really good idea. My car had it when I got the car, complete with the carrier. I keep it in the trunk at all times. You never know when you will want to put the top down.
#76
Hey, that parts PDF makes me wonder if I've been installing my tonneau cover wrong. It shows the front bit flipped upwards. I've always flipped it down and tucked it in behind the seat. Should it be flipped up and tucked behind the seat?
If it's supposed to be flipped up, then that could be a solution to the flapping cover. Instead of using velcro, I could get some more of those snaps (I forget what they are called) like the two that hold each side in place and put two or three in the flap and attach the flap securely to the back of the seat.
#77
We just purchased a 2000 XK8 convertible with 9,816 miles on the clock (it was parked in a heated and carpeted garage for the last 5 years and only driven 1200 miles in that time) to replace our 99 XK8 coupe that was totaled last month. And yes, we always use the cover when driving topless. A friend who owns an auto upholstery shop also recommended not leaving the top down for days on end, in order to preserve both the top and the headliner. Speaking of cloth tops, does anyone here use Ragg Topp cleaner/preservative and do you like it?
Ed Schoaps, Salem Oregon
NCE KTY
2000 XK8 Convertible, completely stock.
NCE KTY
#78
#79
Sam
Your cover should be tucked behind the back seat. I've had my XKR up to 120 and never had the cover lift. I use no Velcro or snaps. I've driven 100's of miles with out the cover every coming out. I also tuck the corners around the plastic corner on the back seat and tuck it in under the body on the sides. If its lifting at highway speeds it may take a little forming, the sides where the snaps are have a solid backing stitched in and a wire on the edge that may have to be bent.
Doug
Doug
#80
The manual says to tuck the front down behind the seat. Also, the side portions that stick up a bit (those that end up over the hinge/lift mechanisms) should be tucked into the body of the car.
Doug
