convertible problem
The pump and reservoir are located behind the right panel in the trunk above the CD player. Fluid level can be seen through the plastic reservoir, max/min marks on the end. Fill is through a small opening at the top. Difficult to see, more difficult to fill. Will take a small hose and some way to pump it.
If low, you have a leak. It is a closed system and does not evaporate. Check the manual bypass valve, the brass 'T' handle in the side of the pump body. Closed if fully clockwise.
The bypass valve is only used when manually raising or lowering the top. I just wanted you to make sure it was closed. If open, even a little, the top will operate slowly, if at all.
Is the leak because of a loose fitting? Leaking hose? Other?
More common problem is a leaking hydraulic cylinder beside the fuel tank.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
