Convertible top: conversion to manual latch operation
#141
That would be a great contribution. My own crude prototype leaves lots of room for improvement!
The more I think about it, I would really try to discourage anyone from plugging the hoses or joining them together. Every time the latch is operated in such a system, we're fighting pressure / vacuum to some extent. Nothing to be gained that I can see, as there are other ways to avoid spilling fluid.
1 5QUART Universal Washer Hydraulic Fluid Powersteering Gas Water Tank Reservoir | eBay
This vendor is local and he will tap the tank with a barbed fitting.
So does anybody know either the fitting size or the inside diameter of the hoses?
I also have to see if there is room for the tank.
#142
Received 6,310 Likes
#143
Its a 1.5 quart the smallest he makes. Which still may be to big for the space. I would think you would only need a small amount of fluid. I am still looking for something smaller
Norri (03-25-2013)
#144
#145
#146
I found a lot of very small tanks 4 oz or 6 oz used in rc planes and cars. If possible could you measure the inside diameter of the hoses? Thanks
#147
OK, so we were talking about fitting a proper reservoir. I'd first like to step back for a minute and say ...
There are only slim reasons to believe using a reservoir is beneficial in the first place.
The manual-latch mod works just as well with the hoses left open-ended in some sort of fluid catcher. Then why a reservoir? While modifying my own car I thought well maybe it would be worthwhile to keep fluid in the abandoned hoses and on the seals in the latch, since I will want to use them again down the road. Hence a reservoir, instead of just letting the hoses drain.
Is this needed or even beneficial? I honestly don't know but it was easy to do (in a crude way) so I figured "couldn't hurt" and went that way.
But I would hate to see what is now a simple $6.00 mod get too complex pursuing a really well-designed reservoir, which may or may not be actually doing any good.
All that said, please see below the prototype's water-bottle reservoir. (Engineers, avert your eyes.) The hose ends are submerged in a few ounces of fluid. A sort of dust cap covers the bottle mouth. Elegant it ain't, but everything rides quite securely in there and I think it will stay put indefinitely ... until it's time to remove it and reconnect my in-tact hoses to the pump. (If you have failed hoses, it doesn't make sense to fit a reservoir, just a fluid catcher. The same arrangement would work for that, leaving out the fluid pool in the bottom of the bottle.)
Probably a hundred designs better than this can be found but, again, how much time and money does it make sense to expend here?
Note to Lorwood: info on the fitting sizes is found at the "manual latch" link within my signature line below.
#148
So I think you are correct in this case, simple is better.
#149
#150
I think this is correct but feel free to correct me if I am wrong
#151
#152
If both hoses are broken, I see no problem here as pressure can't be created in either one. But if either hose is in tact and now plugged, I think there could be a problem. Reason being ...
Take a look please at the schematic of a hydraulic piston below. One such as this drives the latch, by hydraulic pressure, in normal operation, and is driven by the latch when we operate it manually. Hydraulic fluid is incompressible, so when that shaft and piston move there must be fluid flow into one of the piston's two ports, and flow out of the other port. If either port is connected to an in-tact, full-of-fluid, plugged hose then movement is not possible since there is nowhere for fluid to flow to. (One exception: the hose could stretch to take up the flow if it is capable.)
If the hoses have some air in them then piston movement is possible (since air is compressible) but only by building up pressure in the hose we're pushing into, and creating vacuum in the hose we're pulling from.
This is not an ideal situation, which is why I'm not so sure plugging the hoses is a good idea generally. But if your system is working OK, I'm not about to argue with success!
OK?
#153
#154
Dennis just finished the mod and it is working flawlessly. From my perspective this is the most cost effective and surest way to avoid the green shower.
A few observations.
My latch moves freely enough that I never have to use two hands. Once I turn the Allen key the movement of the top is enough to pull or push the latch. I do not know if lubricating the latch would help those who may need to give things a little push.
While the system is no longer fully automatic, for me the knowledge that it is no longer possible to have a green shower is well worth a quarter turn of an Allen wrench.
Many many thanks.
A few observations.
Many many thanks.
#156
Did my testing over the weekend. No fluid out of either hose,(lower one is the one with the break in it) and a slight puff of air from the upper. One side note, I tried raising the top, without first moving the latch into the open position, and the top didn’t move. Before I realized this was the case, I thought something else had gone wrong with the system. Is there a micro switch at the latch, that senses the position, locking out the top raising and lowering?
Dennis07 (04-08-2013)
#157
Just from memory, yes, I think it is a microswitch that senses latch-open. But however it's done the latch must be open for the rest of the operation to go forward.
#160
Ready to do it, but a little relunctant, as top is working so well. But I have the old hoses and know it just a matter of time.(even tho I have the relief valve). One question........ You say the pump may come on sometimes, thinking it needs to close the latch? When may this happen? Could you expand on that.........And again, Thanks for you'r work on this project!![Icon Sultan](https://www.jaguarforums.com/forum/images/smilies/icon_sultan.gif)
