convertible top fluid
The top hydraulic system requires Pentosin CHF 11s fluid. It is available at NAPA stores for less than $20 per liter.
You have a leak that should be repaired if you have lost fluid. Most likely is the top latch. Any signs of green fluid inside the top console? The other high leak areas are the tops of the hydraulic cylinders. Look under the car for wet areas in front of the rear wheels.
There is a small brass cap at the top of the reservoir. It is really not visible but you can feel it and remove with a wrench. You will need a special tool to add fluid. Something along the order of a turkey baster with a piece of hardware store tubing attached.
Wes Steenrod
09-06-2015 06:52 PM
2002, add, convertabile, convertable, convertible, fluid, hydraulic, jaguar, kind, pentosin, pump, reservoir, top, tube, xj8
