Convertible Top Hydraulic Fluid Replacement....
#41
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
I had the pleasure this summer, fortunately my favorite sweatshirt was available for mop up. In spite of the fluid everywhere on the headliner, seats and console, there was no staining. I blotted up the mess and got on with buying the better quality hoses. You cannot tell that there was a hydraulic failure overhead.
#42
Does anyone know if there is ever a group buy from the forum?
#43
#44
I've been reading the forum to learn how the hydraulic system works. I put my top down and it won't come back up. I've tried to follow the directions for resetting the computer by holding down the buttons and removing the battery cable but neither worked. Because the top was down I thought that might be the problem so I manually raised the top and tried again. Neither worked this time either but this time I had a small puddle of hydraulic fluid on the floor. Is there an overflow for the fluid? When I manually raised the top I hope the fluid found it's way back to the reservoir and the leak was from an overflow. Can anyone knowledgeably comment on this?
Also the top latch in the front doesn't want to fully close and the rear windows won't function either. If that helps
#45
Sounds like a lift cylinder seal failed or the hydraulic cable burst on the side of the leak by the rear wheel. There is no overflow...this is a sealed system.
See www.jagrepair.com for extensive details on the hydraulic system and its repair.
#46
my top would only close about 1/3. i had my friend watch the hoses because it would open ok.
he said air was bubbling in the hose when i tried to make it go up.
did some research and decided to use the pentosin 11s. filled the tank and the top goes up and down smoothly.
i bought the pentosin at Advance Auto for $25.
ed
ed
#47
I broke a hydraulic line on my xkr. The tubes wore out and need replacing. I have been reading the info on this website and others to get instructions for replacing the lines. I intended to flush the fluid and replace it as part of the rebuild so I tried taking the pump out. the brown connectors on the solenoids broke. I don't believe that the pump is damaged, just the connectors. Who makes the pump? does anyone know where I can get the solenoids? I've talked to top hydraulic, they haven't told me so far. They want to do a complete rebuild on the pump.
Also, the cylinder on the passenger side at the bottom doesn't look as though I can remove the tube. The connection looks like a capillary tube of some sort. I'm afraid I'll break it. How do you remove the tube from this cylinder?
#49
#51
This is a link to Top Hydraulics they can help you
Link Jaguar Convertible Top Hydraulic System Rebuild/Upgrade Service - Top Hydraulics, Inc
Note Never, Never Force the plug off the solenoids!!!
#52
I am presently selling the Pressure Relief Valve designed by LSI. You can contact me by email gus@jagrepair.com for more information. FYI They are presently on back order.
Wes Steenrod
09-06-2015 06:52 PM
