convertible top hydraulic line
It make sense to build a single piece of braided stainless steel line similar to say a brake line? There are a lot of aftermarket motorcycles brake lines using braided stainless steel lines. I know a couple of places where they can custom make braided lines, but I suppose the hard part is getting the connecting end pieces.
Most braided stainless steel brake lines can easily handle 2000psi (really hard stop) and the really good ones handles 3500-4000psi.
This company carries these hoses and many other stock Jag parts some of which are hard to find, aside from the dealerships. Shipping is a bit expensive so it pays to consolidate ordering from them.
http://www.britishparts.co.uk/.sc/ms...ody%20Fittings
Cheers.
Cheers.
#28
Guest
Posts: n/a
Filling hydrolic pump fluid
Gus, you seem to be the "go to" guy on the Hyd Roof sys. Thanks. I have a 2003 XK8 and the pump has started to stall in operation. I checked the pump behind the right side panel in the trunk. The fluid level is about 1/3 from the bottom, way too low. Can't see a way to access the plastic container and fill it. Can you help? Thanks again.
Go to my page and go to the hyd hose evaluation and go down to the pump. The pump has a filler on the top of the tank, a little hard to get to. I used my wife’s basting syringe with a hose attached to it. It works great and she is still looking for it!!!!
You need to know that the low level means you have a leak and you need to know where it is before it creates a problem with your interior.
Good Luck!
Gus
Good Luck!
Gus
#30
#31
Received 6,310 Likes
#33
got the green shower yesterday! LOL its good i tried the convertible top before the test drive, so this really helped to shave $1k off the *********** price.
I havent opened up the top yet, but when getting the leak above the rear view mirror, is the solution always going to be bad lines? and replace for about $300?
#34
#35
Aus V8S
11-13-2015 11:01 AM
