Convertible Top Latch
The center latch for my convertible top seems to be hesitating a little before it locks in when I close the top. The fluid level in the pump is within the normal range, and I installed a current reducer several years ago. The hydraulic line was spliced a few years ago. Any ideas? I guess there could be a small leak that would reduce pressure and be in an area that is not visible.
I have tried to tweak the hydraulic system on my car so as to produce a pressure pulse just barely adequate to close the latch. Any more than that makes life harder on the hoses. But cutting things close like this, every now and then the top needs a little help ... i.e. manually pulling down on the top as the latch is trying to close.
Pulling down the top like this may be worth a try in your case. Even if you would not want to operate the top this way long term, it would be an informative test.
Helen Serrano
10-02-2016 04:14 PM
oddjob2000
09-15-2016 04:15 PM
