Convertible top latch hydraulic problem
Old 07-07-2017, 04:41 PM
dsd's Avatar
dsd
dsd is offline
Originally Posted by Gus
The hose splice kit that was developed by Jaguar for this type of application was a failure and is no longer available.
I believe they stopped offering it as it didn't really work.
  #622
Old 11-05-2017, 04:24 PM
XK8 Comfort's Avatar
What is the best way to remove the windshield top plate? I see there are two plastic caps that appear to cover fasteners at the ends of the plate. I cannot seem to pry them free and I do not want to muck things up.
  #623
Old 11-05-2017, 04:36 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
There are hidden screws under the edge of the rubber seal at each end of the top plate. Pry the glued on seal a bit to see them.
  #624
Old 11-05-2017, 10:09 PM
Is this the seal you are talking about. I assumed the round piece was a push in clip to hold the seal end in place. Here is a picture.
  #625
Old 11-20-2018, 05:33 AM
frankc's Avatar
Hi, I think this will answer the question above, and a few others. Enjoy https://www.jaguarforum.com/showthre...=1#post1094300
You will let me know if it does resolve your issues wont you?
  #626
Old 01-20-2019, 08:19 AM
ronald29609's Avatar
Hi, You seem to be an experienced electrical guy. Maybe you could help design an electrical replacement for the top latch on 1997-2005 XK8s?
Someone on this forum says that the 2006 XK8s use an electric system.
Regards, Ronald29609
  #627
Old 01-28-2019, 03:50 AM
frankc's Avatar
Hi guys,
There is a lot of postings on this topic!
I had a 'Green Shower'. Bit of a surprise to say the least. To save any hassle with pressure relief vales etc etc I took the easy/lazy option of buying aftermarket hoses. Better and stronger, not to mention cheaper.
Also did a sort of 'how to' as I went along. Some browsing this topic may find it of use at a later date, oh and if you do use it a 'thank you' on the page would be nice.
So this is my thread, enjoy. Click me to jump to topic There are also posts before and after you may find useful too.
  #628
Old 12-06-2020, 09:03 AM
ColnagoCT1's Avatar
Thank you for your great and detailed posting.
If the manual release key is missing, what size Allen wrench do you use instead?
Thanks,
Dave
  #629
Old 12-06-2020, 10:55 AM
test point's Avatar
6mm but it has been awhile. Have an 8mm handy just in case.
  #630
Old 12-06-2020, 03:00 PM
ColnagoCT1's Avatar
Thanks!
BrentGardner
28
04-26-2024 03:08 AM
RaceDiagnostics
12-11-2015 10:12 AM
jdzubas
10-04-2015 09:14 AM
NTL1991
XJ40 ( XJ81 )
09-24-2015 09:09 PM
reedmtn
09-05-2015 08:04 AM
Quick Reply: Convertible top latch hydraulic problem
