convertible top oil - can you name that color
Hi All,
Attached is a picture of a q-tip dipped into the oil for a color test as I was unsure what type of oil was in the car currently.
My level is a little below half full so looks like time to buy some oil for it. I want to be sure I guy the right stuff. It has been working great so I don't want to screw this one up.
PO had work done top and work order from October 2000 listing (2) JLM-21112 and there was a previous with same number earlier that year. No work orders since show top work.
So I need to buy the Penosin CHF 11S right?
Any of the local stores near you stock it?
color of oil
color of oil
Received 4,280 Likes
Was just reading the paper work passed along from PO and found SB 8/99 501-33 noted which sounds like a full system flush. Yea me and Jag for stepping up on the warranty when second owner had an issue. If I understand this correctly they would have done a full system flush, and I suspect that is why it is still working today with the newer synthetic oil.
I will check at the NAPA on my way to work in the morning they look like the best price.
Thanks Steve
Thanks Steve
FS[MidWest]: 2000 XKR Buy it all!!! $1000
julesjag1
04-23-2016 01:42 PM
