Convertible top question
Bad Cattitude (09-10-2013)
Use the search feature of the forum to track down the endless threads and debates about the two options. Personally I opted for the relief valve since it was the only option available at the time. But even though it is the costlier solution, I would still opt for it over the resistor since, at least to my mind, it is the more direct solution and pressure reduction results using this system have been exhaustively measured and confirmed. Doing both would seem overkill and possibly harmful in terms of overly reducing the pressure and the ability of the top to work as designed.
Doug
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
