Convertible Top Will Not Budge - Peacock is open
What could jam up the top so it will not open either with the pump or manually? Can the rams jam up? I can disengage it from the front locking mechanism but can only move it a few inches after that.
I ordered some rams off ebay for 100 bucks so i will try that unless someone has another thought.
You need to unlock the top frame joints at the top of the rams before it can fold. It has an over-center locking joint design when it's all the way closed. Just behind the rear windows, inside the headliner, you can reach the ram tops with your hands. Push down on the joints at this location until they move enough to unlock. Then you can lower the whole top the rest of the way manually.
The following 3 users liked this post by Geraldius:
Dennis07
08-13-2020 08:40 PM
WaltB
07-12-2014 11:43 AM
