Convertible top Window problems
When I activate down button the back windows go down, but the side windows stop half way. The top goes down ok and I can get side windows down with door buttons.
All was ok until I removed drivers seat to try and fix airbag 2-2 flashing. Cleaned connectors reinstalled but light still on and now the top deal??
Any ideas? Thanks Ken
Ken, it sounds like the window has lost its "memory". To reset the memory hold the button raising the window until you hear a faint click a few seconds after the window is closed. Then lower the window. Again, hold the down switch for a few seconds after the window is fully down. Until you hear that faint click again. The memory is now set.
Then try lowering your roof again and see if all is well.
Jack
Jack
bvpusa (08-04-2014)
msdg137
09-16-2015 06:24 AM
