Convertible window control
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
After not driving my 2000 XK8 during all the cold weather here in East Texas my automatic function of the windows on this convertible is not working correctly. When I open the door with the windows up they lower slightly (so far so good). When I close the door the window does not go back up and then pop down slightly like it is supposed to do. When you open it again the window drops again a small amount. If you continue to open and close the door the window will continue to lower a small amount until it is eventually all the way down. Both windows malfunction the same way. If you lower the top with the windows up they really act up. When the top is half way down the windows (both) will bounce up and down real fast for about three cycles.
I am desperate to fix this, but don't even know where the control module for this function is.
NEED HELP.
EZDriver 2000 XK8 1995 XJ6
NEED HELP.
Hello EZDriver 2000 XK8 1995 XJ6 ,
Go to https://www.jaguarforums.com/forum/s...ad.php?t=49897 . There was a thread concerning your issue. Hope this helps.![Icon Band](https://www.jaguarforums.com/forum/images/smilies/icon_band.gif)
Bassmania
Bassmania
99xk8guy
06-05-2023 06:28 AM
