Convertible Window Reset - won't hold in memory
HI,
I have an '02 XKR convertible and for the last year or so, the window reset will not stay. I roll the windows down, listen for click, roll windows up, listen for click and everything works fine for a day or two and then it stops working and i have to go through the same procedure again. Happens to both drivers and passenger door window which seems odd unless they are both controlled by the same mechanism.
Do I need something replaced and if so what? Or is there something else I need to do?
Thanks for the help!!
Kip
Kip
HI,
Kip
Kip
My own lower limit for a battery after an overnight, in warm weather, would be around 12.35 volts. Anyway, anything under 12.5 is getting a little long in the tooth.
99xk8guy
06-05-2023 06:28 AM
trosty
26
12-18-2022 06:40 PM
