Convertible XKR. How to close door without power ?
Welcome to the forums Joesstuff,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post technical questions about your model.
I'd just get a battery charger or a jump pack on the battery and that will get the juice going enough to get it to drop. You'll not have programming to have it go up, and it's likely the battery will die again and lose it if you were to program the windows. That's by FAR the easiest route since the other options all take longer and are futzing around.
+1 on jumping. If you need to you could lower the window a smidge before disconnecting power. That way you have egress while you sort out a new battery.
I suppose unlatching the roof will work. Just don't forget you'll have a roof header gap by not being able to rescure it before you can drop the window.
John
John
