coolant expansion tank
Going to bite the bullet and replace the coolant expansion tank even with only 45,000 on the clock. Some one recently mentioned they had found a good price on one with a new cap and level sensor included. Did a search and can't find that thread. I'm open to suggestions for the best source of a new assembly.
Thanks guys.
Thanks guys.
I got mine from the dealer, a year or so ago. I just remember them giving me the part and a bill and I asked them if they could do any better on the price and they gave me an additional 10%. Just ask you might get it.
I have had luck with Car Quest on parts they can source thru World Pac. I just did not think to try them on this one.
If you have the correct jag number just call Car Quest an they will cross reference it to see if it is available.
EZDriver (05-08-2012)
Received 2,190 Likes
Mex has not been around here since last year. Here is a discount source for the Jag factory part: 1997 JAGUAR XK8 Parts - Direct JPLV Porsche Parts.com
Since I bought my xk8 used, I've noticed a faint coolant smell after every use of the car. I finally noticed that coolant is weeping from the seam in the tank, very slowly in small amounts.
Rather than buy a new Jag tank for $150-$250 which will eventually have the same issues, I am thinking about getting a welder to make me one out of aluminum. If he can do a good job, I might recommend him to others here... as I'm sure we'll all have leaking tank seams sooner or later.
BTW, I bit the bullet and spent the $150 on a new tank, sensor and cap.
My question in all this is: Why replace it unless it's leaking? I don't often replace $200 parts unless thay are showing a failure mode. Belts and hoses are good PM things but XK8 coolant tanks are low wear items and I have seen little indicating that they all fail at some particular point. The ones for the XJ8 x350 are another matter, they are a common failure point and replacing them at about 60k is just good PM.
I suspect many people who "smell coolant" but cannot figure out where it's leaking may have this same issue? It took me a while to notice this because I had to be on the passenger side of the engine bay while the engine was running (not something many people do).
I got lazy & haven't made any progress on commissioning an aluminum tank. My car sensed my complacency, so it decided to teach me a lesson
I was driving along in the 100+ degree heat, when I heard a faint pop. About 30 seconds later, steam started billowing out from the hood so I pulled over & stopped the motor. Peeking under the hood, I discovered that the tank completely separated in two (at the seam), throwing all the car's coolant over the engine
Fortunately the tow truck only took an hour to rescue me... in that heat I was afraid that I'd separate at the seam, too!
I got mine off of ebay $192.50 shipped.
