Coolant hose part number question
I just replaced that hose (and the EGR cooler hose) on a 2006 S-Type R.
They run under the intake to the thermostat mount housing and coolant outlet pipe.
I THINK it is AJ83706, but it might be superseded.
The hose IS NOT in the cooling section!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Buy the other one and do BOTH the throttle feed and EGR return (AJ83921) since you will be under the intake anyway!!!!!!!!!!!!!
Look in the
XK8 Coupe/Convertible From (V) A30645/AIR AND FUEL DELIVERY SYSTEMS/AIR DELIVERY SYSTEM COMPONENTS #3
and
XK8 Coupe/Convertible From (V) A30645/ENGINE MANAGEMENT/EMISSION SYSTEMS/EXHAUST GAS RECIRCULATION SYSTEM #14
Replace the 'loop' hoses also!!!!!!
bob
Look in the
and
bob
Motorcarman: thanks for the quick reply! I think this hose might be different on a XK8, as it twists around for about 8" and then connects to an accessible tube which _may_ go under the manifold but it's certainly not rubber there.
At some point I'll probably replace all the hoses but they all seem to be in excellellent shape for now........except for this one that I managed to bodge up on a different mission.
CoventryFlagship
04-20-2016 05:52 PM
webbeing
04-18-2016 11:46 PM
