Coolant leak
Old 03-04-2014, 11:02 AM
batroute's Avatar
Question Coolant leak
I've tracked down a small coolant leak to the heater hose where it connects to the non return valve - presumably the valve, being plastic, should be replaced at the same time? Am I right in thinking this is not part of the infamous octopus hose assembly?
Old 03-05-2014, 07:40 AM
GGG is offline
Received 16,865 Likes on 12,186 Posts
Leaking at the Three Way Connector (item 6)?
If so, it's listed separately from the heater hose.
batroute (03-05-2014)
Old 03-05-2014, 08:41 AM
batroute's Avatar
Thanks Graham - I've managed to narrow it down to the heater valve to bulkhead hose - there is a non return valve included in the hose - part number HJA6739AC for the benefit of any other member that has this problem in the future
arskemp
09-21-2015 02:19 PM
Lannyl81
09-19-2015 08:07 PM
OkieTim
09-08-2015 04:48 PM
Xkr x100
09-06-2015 08:50 AM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Coolant leak
