Coolant leak?..
Coolant leak?..
Hello , I have a pristine 4 .0 2002 xk8 second owner is myself and I have an issue with the coolant level reservoir depleting ...once a week I put one small bottle 10 oz bottle of water in the reservoir.This has been going on over a year and I have taken the car to numerous shops and every time it’s a problem not solved and a new part and expensive labor bill.I have had the reservoir replaced, the cap replaced, the radiator replaced, the water pump replaced , the water serpentine hose replaced, the fitting plastic fitting behind the block, thermostat housing...and it’s still using a bottle a week...i drive the car about 66 miles a week tops ...and no signs of water on the garage floor., no water in oil, no overheating, just a warning on the dash coolant level low..
Hopefully some here can assit me and advise me what to check...thanks guys
mit2700
03-28-2020 11:39 AM
Kane Emery
16
06-26-2019 12:08 PM
