Coolant leak from around the cap
Ok, will do. I've done about 2000 miles over the past month or so and before that it's been driven around town and not really driven properly.
Really appreciate the replies. I will check the seam too, as this is where the leaked coolant collects. If the seam is on the bottom half of the tank, then I know it's just a cap as no coolant has run past the join, will have to check again. Hopefully it will be worn cap and nothing else
Many thanks
Many thanks
Thanks for the replies everyone. So far I can see a small trickle from the cap, will change the O rings on the cap and take it from there . Something I didn't mention was I topped up the oil the other day and found a few bubbles on the dipstick �� , oil looked clean and fresh though. Coolant loss and bubbles on the dipstick sounds worrying? Even though leaking from the cap? Anyone seen this before? Only has 74000 miles.
Check your again oil after letting the car sit undisturbed overnight.
Does your oil have any additives?
Bubbles are different from foam. Foaming can be a sign of overfilling. Don't worry about a small amount (one quart or less) of overfill. The issue is when oil becomes so foamed up that the oil pump pick up cannot get enough liquid oil to lubricate engine.
If coolant has seeped into crankcase because of leaking head gasket, or any other penetration, the oil will eventually become milky in color.
OkieTim
09-08-2015 04:48 PM
