Coolant Leak finder dyes - any Warnings?
Old 11-17-2019 | 09:49 AM
Johnken's Avatar
Default Coolant Leak finder dyes - any Warnings?
I've decided that a leak finder dye for my coolant system might be the best /fastest way to find this slow leak. I was surprised to see some brands warn: Not To Be Used with Dexcool.
I suppose nothing should surprise me, but I would have thought - hey it's just a simple UV dye, how could there be Compatibility issues. . .
Well, given that, I better check since this is my first time to use it (my pressure tester always solved the mystery before).
Any warnings or heads ups I should watch out for using any brand? Can I assume "universal " brands are ok to use?
BTW, does this dye last long? I figure someday years from now I may need to do this again. Do the old dye markers throw you off the trail next round?
Thanks, I won't buy anything til I see what you think.
John
DavidYau (11-17-2019)
Old 11-17-2019 | 12:37 PM
Jon89's Avatar
Are you saying that pumping up the system with a pressure tester kit has not revealed a leak?
Johnken (11-17-2019)
Old 11-17-2019 | 01:22 PM
markhud's Avatar
I understand that the "universal" UV dyes can gel the Dexcool coolant which would be a nightmare. I was not willing to take the chance and obtained a small bottle of the AC Delco dye from a local GM dealer for around $7.00. Call first, not all dealers carry it in stock. The UV characteristics wear off in a short time. I used the UV light about a month later and the coolant did not react to the UV light source.
The following 2 users liked this post by markhud:
Johnken (11-17-2019), volkris (11-30-2019)
Old 11-17-2019 | 01:23 PM
Johnken's Avatar
Yes Jon.
Thanks Mark.
John
Ken2839
10-03-2016 10:42 PM
Drak
12-11-2015 04:45 PM
johnro6659
02-20-2013 12:37 PM
vettegood
11-24-2012 11:31 AM
sinatrakat
09-13-2010 05:20 AM
Quick Reply: Coolant Leak finder dyes - any Warnings?
