Coolant leak - Likely causes?
Just did a little inspection. Topped up my fluids for the time being until I feel like replacing them all. Noticed a coolant leak. Doesn't appear to be leaking from the reservoir or hose into the mechanics... so what does that leave me left to check and where?
I know it's not going to be anything major so I'm not too worried. It's been exposed to extreme cold over the winter as well a big variation in temperature over the past couple of weeks... from near summer temps to sub freezing temps in a matter of hours. I'm assuming a piece of rubber or plastic gave out as has happened on my Camaros in the past.
On my 06 the coolant leaking last year was from an Octopus hose. I took the easy way out and hired someone to change it. After seeing the parts, and where they go I was very glad I hadn't tried it.
Of course there is also the radiator hoses and thermostat housing issues - These are easier to reach.
Thanks guys.
I used the pressure test kit, three times and got no results.
I had the car safetied yesterday and while it was up on the lift, checked... no evidence of a leak.
There's been no more puddles in the driveway and the level looks to be holding now. Not sure what that's all about.
OkieTim
09-08-2015 04:48 PM
