Coolant level low
Hello everyone,
I have the COOLANT LEVEL LOW warning.
I replaced the sensor, but the warning is still there.
Does it take time to reset or should it register the new sensor right away?
If it doesn’t go away, I guess the next step is to replace the reservoir.
Any suggestions?
Any suggestions?
Can you check the resistance across the sensor terminals when the tank is empty and full by syphoning out the coolant temporarily? You can probably find what the value should be online. Compare these values with the values for the original sensor. I would have expected that the new sensor would work immediately.
Richard
Richard
Todd Wiens (12-14-2023)
The following 2 users liked this post by RJ237:
motorcarman (12-12-2023),
Todd Wiens (12-12-2023)
Sometimes it's better to just replace the expansion tank, which comes with the sensor, and be done with that.
Usually, by the age the sensor has failed, if it failed first, not long after, the tank will start leaking at the seams. And if it isn't leaking, it's likely the float is stuck, which I bet is your situation.
The following 2 users liked this post by giandanielxk8:
Jag#4 (12-12-2023),
Received 1,686 Likes
PS: You can attach ohm meter leads to the sender (while it’s in place) and move the magnet up and down with a wire bent with a hooked end. The meter should show a different reading when the magnet is moved to the top then dropped down.
this is easier done on the workbench than when having the tank installed.
Z
Z
Essentially yes. Some use a turkey baster. I use a cheap Harbor Freight hand suction pump kit. Suck out as much coolant as you can, then place old towels all around the base of the reservoir to soak up as much of the coolant that will spill (or just dribble if you are lucky) when you loosen the clamps, pull the hoses, and remove the reservoir. I replaced what I presume to be the factory reservoir in my wife's 2006 XK8 six or seven years ago. They all eventually begin to leak at the nozzles or at the seams, so I have a brand-new replacement reservoir sitting on my garage shelf awaiting installation when the time comes....
The following 2 users liked this post by Jag#4:
giandanielxk8 (12-12-2023),
The following 5 users liked this post by Throwback:
Jag#4 (12-13-2023),
michaelh (12-14-2023),
Todd Wiens (12-15-2023),
Y2KJag (12-16-2023),
zray (12-12-2023)
I’m changing out the reservoir. I was trying to remove the upper hose, the one in the corner, next to the blanked out hose attachment. The hose is rubber, then plastic tubing, then rubber. The plastic is brittle and it cracked. Any quick replacements out there or do I have to buy the Jaguar part?
UPDATE: I ordered the factory hose. To get me by until the factory hose arrives, can I just run a rubber hose, similar to the two ends of the factory hose, all the way from the reservoir to the thermostat housing?
Y2KJag (12-16-2023)
I used a rubber hose for a permanent solution. Makes no sense to me to have rubber/plastic/rubber. My coolant tank was brittle and broke the nipple off the tank. Still looking for a metal thermostat housing, mine also broke off a nipple on that. It always something!! TM
Todd Wiens (12-19-2023)
