Coolant Level Sensor?
The design of the XJ/XK coolant system is a pressurized reservoir and then an overflow bottle. Fill the reservoir cold. As it heats it will drive the surplus coolant into the overflow container and then suck what it needs back into the reservoir as it cools. Given a little fluid in the overflow it will regulate itself to where it thinks it should be.
mjlaris (12-02-2013)
The bad news is that it often takes a new expansion tank. The good news is that they come with a new cap and sensor, plus they are easy to change out yourself. Plenty of threads here to show you how.
I had work on performed on my coolant system this summer, which in Texas is HOT. This fall, when the weather turned cold, I keep getting an intermittent "Low Coolant Level" message. When I checked the tank level it was down a little from the neck where the cap is located. However, when I read the manual, I was not certain that I understood the directions correctly and didn't know there was another expansion tank. I understand now and believe that this is the result of the change in average air temperature from about 100F to 50F. Thanks for the info.
Mark
Mark
This is the Atmospheric Recovery Bottle (arrowed in red) in the RH front wing.
![Coolant Level Sensor?-atmospheric-recovery.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/64499d1480970598t-coolant-level-sensor-atmospheric-recovery.jpg)
Excess coolant from the Expansion Tank goes through the transfer pipe (arrowed in green) and is drawn back as the engine cools down again to maintain the correct level.
If the Atmospheric Recovery Bottle fills completely, coolant is dumped onto the ground beneath the vehicle through the overflow pipe (arrowed in yellow).
With the exceptionally hot weather you have had in Texas, this is quite possibly what has happened to cause the slight drop in Expansion Tank level.
As long as you have no leaks, there's nothing to worry about.
Attachment 64499
Attachment 64499
Thanks Graham, this was my conclusion as well after you guys explained the design of the system.
Mark
Well, after reading this I rooted around the little reservoir and found a couple of surprises. Seems there was this connector hanging around loose with a jumper wire that had come free. Also found that the outside part of the sensor was broken off. Well that explains the low coolant warning and probably means that the weird looking thing I threw away a couple of months ago was a new sensor that the PO "meant" to install. Just shoot me now.
And so goes life in the big city.
The sensor is not under pressure. It slides into a tube built into the tank body. There is a magnetic float inside the tank which activates the reed switch in the sensor through the plastic housing.
Guy-Pierre Boucher
09-16-2015 05:55 PM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
