Coolant level sensor
Old 05-10-2012 | 11:19 AM
steveinfrance's Avatar
Default Coolant level sensor
From a number of posts on the expansion tank it seems desirable that this float switch actually works.
If I take off the filler cap (engine cold of course) and push the float down with a bit of wire what will happen ? (sensibe answers only please).
Will the 'Low Coolant Level' warning reset automatically as soon as I release it or does it trigger a fault state that needs resetting ?
Does the engine need to be running or just ignition on ?
Old 05-10-2012 | 11:48 AM
2002XK8Orlando's Avatar
The switch will default to "low coolant" if it is broken. There is no need to check to see if it is working...if you don't have a "Low Coolant" message then you know 2 things (provided you haven't unplugged and jumpered the switch):
1. You have good coolant level
2. Sensor is functioning properly
when it malfunctions it will throw a false positive indicating "Low Coolant" but impossible for it to throw false negative
steveinfrance (05-10-2012)
Old 05-10-2012 | 12:00 PM
Thank you, that's all I need.
mrplow58
01-21-2024 06:53 AM
Guy-Pierre Boucher
09-16-2015 06:55 PM
KarimPA
09-12-2015 09:15 AM
JimMLiny
09-09-2015 09:13 PM
KarimPA
09-03-2015 08:32 PM
Quick Reply: Coolant level sensor
