coolant level . xlr 2001
In my car, half a tank does not show a low level warning. It could be that your float sensor is stuck or needs replacing.
There is a brief description in this thread:
https://www.jaguarforums.com/forum/x...nt-low-100966/
tanngo (09-26-2013)
tanngo (09-27-2013)
The correct coolant level is to the bottom of the filler neck on a COLD engine:
![coolant level . xlr 2001-coolant.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/56228d1480969716t-coolant-level-xlr-2001-coolant.jpg)
There is no need to leave free space for expansion. As the engine heats up, excess coolant goes into the Atmospheric Recovery Bottle behind the front wheel arch. As the engine cools after switching off, it is drawn back into the Expansion Tank again to maintain the correct level.
tanngo (09-27-2013)
tanngo (09-27-2013)
Yes - liquid is returned to the tank.
It's easier to explain the liquid flow with a diagram:
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/56283-coolant-level-xlr-2001-xk8-expansion-tank-atmos.jpg?amp;d=1380324804)
As the engine warms up, the coolant expands. Excess liquid from Coolant Reservoir (item 1) goes through Expansion Hose (item 8) to Atmospheric Recovery Bottle (item 11).
As the engine cools, the coolant contracts. The resulting vacuum draws liquid back from the Atmospheric Recovery Bottle (item 11), through Expansion Hose (item 8) back into the Reservoir (item 1).
This is why the level in the Reservoir (item 1) should always be up to the filler neck - no coolant is lost.
After changing the thermostat, you could have air in the system. It's important to fit the thermostat with the bleed hole (arrowed in the following diagram) at the top:
This allows the air to bleed out.
![coolant level . xlr 2001-thermostat-giggle-pin.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/56284d1480969716t-coolant-level-xlr-2001-thermostat-giggle-pin.jpg)
The following 3 users liked this post by GGG:
tanngo (09-28-2013)
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
Johnken
09-15-2015 05:46 PM
