Coolant light XK8 2005
I've moved your question from X308 to XK8/XKR forum. This is the place to post questions about your model.
If the coolant is low, top it up with orange OAT coolant. Often the light is set by a faulty (sticking) level sensor in the Expansion Tank.
Also, are you sure you are not overheating? The temperature gauge does not work as such, and will remain in the middle of the range until you are very hot - and then it might be too late to do anything.
The coolant level sensor will give a coolant low message on the instrument cluster screen.
+1 on they do stick and moving it up and down gently will free it up. If you open the reservoir and it is low add coolant that matches what you have in the system.
If it continues to loose coolant you will need to do a pressure test and find the leak.
JaguarVDP
12-01-2018 09:33 AM
JimC64
03-02-2015 08:07 PM
