Coolant overflow hose
I have a leak at the engine end of the coolant overflow hose (2000 XK8). I ordered and received a new hose ($26 incl shipping from autopartswarehouse.com). However, the existing tube or hose has two circlips, one at the engine and the other at the coolant overflow tanks.
I was wondering if someone can help - are the existing clips easy to take off and more importantly are they reusable? I havent tried to take them off yet for that reason.
Thanks for any info.
Kal
Kal
There is a special tool for those 'clic' type hose clamps., but they can also be removed with a pair of pliers and a small flatblade scredriver as follows:
Pry open the clamps with a small screwdriver in the rectangular window on the clamps. While gently prying, squeeze the clamps together by their outermost ears with a pair of pliers.
They can be reused as long as you are gentle and do not deform them.
kvmentor (02-18-2011)
If they deform just get some breeze clamps.
http://www.breezeclamps.com/euroseal.htm
these should be readily available.
