Coolant Overflow Tank Filling
During routine checks, noticed the overflow tank is empty. How do you add fluid? Seems silly to have to jack it up, remove wheel and fender liner just to add fluid? Has to be a better way or do I just leave it empty? Running perfectly, no heat issues. On other cars you top up the coolant via the overflow (which is easy).
You could get a bottle of coolant and 'pump' it into the atmospheric catchment tank from the pipe/hose at the coolant reservoir?(the way the coolant cap does)
A 'syringe' type pump would take a really long time unless it was a large volume pump.(a few CCs at a time is tedious)
A large funnel with a 'stepped-down' fitting will gravity feed the tank, albeit SLOWLY.
RJ237 (06-17-2024)
My recommendation is simply to fill the black header tank so it just starts to comes up past the ridge in the bottom of the neck and check it again every couple of weeks, as is good practice anyway. If the level has dropped at all, then refill it to the same place. After a few fills you should find that the level is still up to the top when you check it which is where it should be. The atmospheric tank will still not be filled 50% but the cooling system will work properly and it's a lot less fiddly than trying to fill the tank remotely.
Richard
motorcarman (06-18-2024)
You've got to love the challenges that these cars throw up!
and inserted the tube on the syringe and filled it from there observing progress from right front door hinge area with flashlight in dim lit garage. Doesn't take long.
Jack
Received 1,701 Likes
It only took me 30 minutes to remove and replace the passenger side wheel (USA) and the wheel liner, then fill the atmospheric tank to the proper level. 1?
That doesn’t seem like too much time. Then the job is done. And without having to go back over and over adding coolant a little at a time.
toaster (06-22-2024)
Just re-use when the fasteners are not disintegrated.(probably NLA anyway?)
The main plastic 'push-pin' that breaks is XR8-8883.
The following 2 users liked this post by Rex:
motorcarman (06-20-2024),
Redjags (06-19-2024)
