Coolant Reservoir Tank Quality ?
The plastic coolant reservoir tanks in the S-Types are notoriously lousy and tend to crack and break at the hose nipple locations if you just look at them funny. The vast majority of these tanks must be replaced every few years due to their brittleness. The S-Type section of this forum is usually filled with folks complaining about coolant leakage, and 95% of the time the culprit is a cracked and leaking reservoir tank....
Our XK8 coolant reservoir tank appears to be visibly sturdier and more robust than our S-Type tank, and I see hardly any posts here on the XK8 section of folks with leaking tanks. Are the XK8 tanks indeed superior to the S-Type tanks?
Dont really know. But I have only replaced mine once. That is because the fitting on the bottom of the tank leaked at the o ring. Have to buy a new tank because there is no repair. Its not what I would call brittle. We all know about brittle plastics on these cars and this tank I would not classify as brittle.
The plastic coolant reservoir tanks in the S-Types are notoriously lousy and tend to crack and break at the hose nipple locations if you just look at them funny...................Our XK8 coolant reservoir tank appears to be visibly sturdier and more robust than our S-Type tank, and I see hardly any posts here on the XK8 section of folks with leaking tanks. Are the XK8 tanks indeed superior to the S-Type tanks?
I've heard of several failures with these tanks but it mustn't be anywhere near the same as thermostat towers or the aftermarket suppliers would have jumped on the opportunity.
On the first car replaced the reservoir at 106k miles due to a pin hole leak onto the left CAT. No indication of previous replacement and I have all the repair records.
On current car replaced original reservoir due to a pin hole in the body at about 45k miles with a used one. Twenty k miles later replaced that one for a pin hole in the body. Neither was at a seam or any other place that would indicate damage.
The plastic reservoir is obviously of lesser quality than you would expect from a car of this reputed quality . . . XK8 included.
KarimPA
09-12-2015 08:15 AM
OkieTim
09-08-2015 04:48 PM
