coolant tank
In the long run, I'd advise changing the tank. Unless otherwise noted, they come with the cap and sensor, so you're all set.
These are known problem areas, so bite the bullet and get the full tank setup. Change it once and done. Buying piece by piece is more expensive.
These are not hard to source. Check all the usual suppliers and expect to pay ~$150 USD.
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
will do GGG... jaguar has exp.tanks for 160.00 with tax think i should go to them or by on line for 137.00............. would it be better to go to jag for the few extra dollars...... are there parts better or the same ???
AFAIK, there are no aftermarket suppliers for the tank. They are all from the same manufacturer.
SNG Barratt - The Ultimate Jaguar Parts Specialist
Jaguar EXPANSION TANK COOLANT RESERVOIR - MJD4400AB
I've used both of these guys, superb service, and both give a discount for members of the forum.
SNG Barratt USA (05-27-2014)
tony bosco (05-27-2014)
Don't forget the forum sponsors
Word of advice when fitting the new tank: Be very careful when disconnecting the pipe from the tank to the thermostat housing. The plastic section becomes very brittle and is likely to break if you flex it when removing the pipe from the tank. Either be very gentle, or be prepared with a length of replacement hose (most people replace the hose with ordinary coolant hose from any motor factor rather than the original plastic/rubber combination hose).
Good luck.
Good luck.
tony bosco (05-30-2014)
What about the Jaguar Hose Clamps? My Jaguar XK8 has some odd clamps that I have never seen before. About 1/2 inch (12 mm) wide with a portion that is folded back and forth several times. I don't want to mess with them without understanding how they work. How do you remove them? Can they be reused?
Thanks, John
Thanks, John
