Coolant temperature sensor leaking?
If you are talking about the sensor that is installed in the top plastic outlet manifold, I had that same problem on my wife's 2002 XK8. I just replaced the outlet manifold, that came with a sensor already installed in it with a new part, at the same time I changed out the original plastic thermostat housing with the aluminum unit. No more leaks. I did not want to chance tightening the sensor in a nine year old plastic part. I purchased the parts from Motorcars Ltd.
Bill
2000 XKR Coupe
2002 XK8 Coupe (Deb's)
2002 XKR 100 Coupe
Bill
2000 XKR Coupe
2002 XKR 100 Coupe
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
