Coolant top hose random issue
Hi have had this vehicle 8 years and about 18 months ago the top hose just popped off the engine at the top front. I checked the clip (worm thread type not sure if it’s original or replacement) reset the hose and made sure it was on tight. It did the same thing one more time and since then I have had the water pump replaced when there was a pressure and leak test done and all was well. Then I had to replace the cracked expansion tank. This was all several months ago and this evening after running a few errands I pulled into the garage, no steam or smells and then went back about an hour later to see all the coolant on the ground and lo and behold the top hose had blown off again. When I say blown off, the end was sitting back about 3” from the engine so it’s not like it just wiggled loose. Also it must have happened after I walked away from the vehicle or I would have smelled it and/or seen the steam. What’s so random is that I have done 4hour trips on the freeway without stopping and without issue and then I run some errands and the hose blows off! Is pressure building up somehow? If I had head gasket issues I think it would have other symptoms too?
I had this problem on my x308. I found that the tube had lost the retainer lip on the plastic pipe. The very end of the pipe is supposed to have a register area that is larger the the pipe itself and once the hose is inserted over it and the clamp is in place the clamped hose can not slid over it. Try going to www.sngbarratt.com , click on find parts and take a look at what a new one looks like compared to the you have.
The following 2 users liked this post by avern1:
Abby's Guy (03-29-2021),
RJ237 (03-18-2021)
DavidYau (03-19-2021)
