coolent problem
coolent problem
Ok
changed the following
Waterpump,thermostat,ali tower fitted,new top hose & new tank cap.
The top and bottom hose feels like its under great pressure when at running temp (guage sits half way) only a guess if its telling the truth,engine runs sweet, no coolent going into overflow tank under wheelarch now my small tube that goes from tank to tower has developed a small drip at the tower end where it changes from plastic to rubber which I will have to order yet another part...any ideas.... head gasket perhaps? surly if it was then it would push coolent into tank under wheel arch...perhaps its time to scrap it.
The first thing is to ignore the temperature gauge as any accurate indicator of overheating. Only WhiteXKR's RealGauge or something like TorquePro will give you a correct coolant temperature reading.
I'd suspect and eliminate a sticking thermostat before looking at the more drastic possibility of a head gasket.
Did you change the water pump etc because a of cooling system fault or as preventative maintenance?
Received 2,390 Likes
Best of luck, keep us posted.
managed to find some pipe to replace that stupid plastic stuff...I think I may have a big air lock as when the stat opens the bottom rad hose starts getting hot from stat back down to rad rather than the other way around so must be an air lock or blocked rad I would have thought...flush out tomorrow and see what happens
If the fans are not running, the cooling fan module may need replacement. This module is mounted between the fans. If it goes bad, the engine can overheat in traffic very quick. It is a computer that works off of the ECU to control the fans and their speeds. To see if you have a head gasket leaking compression into the coolant, just open the overflow cap ad watch the coolant with the engine running. If the gasket is leaking, you will see bubbles in the coolant.
By the way, to be sure you don't have an air lock, open the system cap and run the engine until the thermostat opens (the lower hose gets hot). This should clear any air locks. If there are air locks, you will also see bubbles in the coolant as they become cleared. Don't mistake this for a leaking head gasket.
