copper grease or just any anti-sieze compound for the wheels?
Old 06-19-2012, 04:27 PM
OhioXK's Avatar
Default copper grease or just any anti-sieze compound for the wheels?
Is using copper grease on the wheels a must or can some other anti-sieze compound be used instead?
Old 06-19-2012, 04:38 PM
RCSign's Avatar
I use anti seize compound, have been using it for over thirty years beginning with my MG's, never had a problem.
OhioXK (06-19-2012)
Old 06-19-2012, 05:00 PM
Doug's Avatar
Received 10,945 Likes on 7,190 Posts
<shrug>
For decades now I've simply used a smear of wheel bearing grease. Works grrrreat :-)
Old 06-19-2012, 05:15 PM
GGG is offline
Received 16,865 Likes on 12,186 Posts
Copper (or any other) anti-seize / grease will prevent seizure. It only needs to be smeared thinly over the contact points between wheel and hub.
However the bright copper colour of 'Copaslip' anti-seize looks bad if excess gets on the face of the alloy wheels or the inside of the rims.
I use the Aluminium equivalent available from Land Rover Dealers which is the same colour as the alloys.
kevinl
10-31-2019 06:15 PM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
Richard_gib
09-12-2015 07:08 PM
mrplow58
09-09-2015 11:27 AM
JagLove86
09-06-2015 10:36 PM
Quick Reply: copper grease or just any anti-sieze compound for the wheels?
