Hi all, looking to replace the battery in the xk8 I know that the OE battery for a XK8 is a VARTA made in Germany. Part Number C2D22312. Specification is 90Ah and 800 amp, dimensions 354 x 175 x 190mm is 019 and the short code is H3. So I have looked on Vartas web site and put the part number and it brings up a varta Blue Dynamic 595 402 080 near enough that same spec only the short code is G3. Any thoughts on this and if its a good idea to get the battery? I will leave the link bellow.
the battery capacity is different than say a charging adapter output. the numbers for a battery represent its capacity under load for a period of time. note that voltage drops due to insufficient capacity can damage electrical components as things run hotter. install the highest reserve battery that you can. Bosch has a 1080A lead acid for a very good price.
