Correct Nav DVD for 2006 XKR
Hi Mosely,
I have an 05 XK8, which I presume has the later BM9JG91F disc. Although I've personally never used the older version, it would make sense to me that the newer version would contain more updated maps/POI data and therefore would be more desirable. That being said, I no longer use mine as I've changed out my head unit thereby rendering my nav inoperable. If you're looking to purchase a disc, feel free to PM me.
I have a 06 XKR with the Alpine system. The newest disk is a 2005 version produced by NAVTEK. I have searched high and wide for over a year and there is not a newer disk available. Jag has since moved to a 2 disk system. The only solution I have found is to replace the system with a Garmin, which is upgradable from the internet, and I am in the process of doing that, thanks to this forum.
Go Luck
Go Luck
Hi Mosely,
