Correct throttle percentage at idle? Wisdom needed.
Hello guys-
I had my throttle body off last week, and obviously had to reinstall the throttle cable when I was finished.
I've got the Torque OBDII app on my phone, and presently my throttle percentage is at 1.0 - 1.2% at idle, which seems a bit low. There's an ever-so-slight struggling of the engine at this throttle percentage.
Can anyone tell me what the proper throttle percentage should be at idle?
Thanks in advance for your help.
But I could be wrong. I've recently had my fuel injectors cleaned and flow-tested...then did a hard reset of the ecm just this morning...perhaps the car is just learning to operate with the increased flow ability of the injectors.
I'm not familiar with the "bypass valve" for regulating idle...is that present on my 1997?
My throttle position sensor shows 1.9% at idle (650 RPM) Click the image for the big version.
![](http://matt.zenfolio.com/img/s3/v26/p148755490-5.jpg)
I know its a little different engine, but it should be close. I adjusted my cable with AE with the engine off so that there was 0% on the TPS, but the absolute throttle position is about 0.3% higher when the engine is running (at idle).
The Coupe (03-20-2012)
xjrjag
09-27-2015 01:53 AM
joesoap
09-10-2015 01:09 AM
