Corrupted file in immobiliser next step
Old 02-23-2023, 09:25 AM
xalty's Avatar
Received 1,067 Likes on 857 Posts
Originally Posted by Speedy G
Ok i have an update finally So i have had my battery on charge the last 2 days yesterday i was ready to give it a try and boom put the fully charged battery in the car the trunk light popped on and the little red light by the shifter stopped flashing and the car started right up the no trac abs and restricted performance lights were showing in the cluster i drove it for about an hour or so and the
i guess they took the key add out of the thinkdiag poverty edition. my launch still has it 🤷‍♂️
  #42
Old 02-23-2023, 09:50 AM
fmertz's Avatar
Received 1,519 Likes on 1,064 Posts
If you are able to start the engine, it means the crypto exchange between the car and the key works, and this is no longer the root cause of your issues.
I hope your battery concerns pan out. If not, I would concentrate on the (in)ability of the car to somehow effectuate the communication of the key protocol over the applicable data network(s). Check the data network layout in the electrical guide. Identify which network the KTM is on (SCP or ISO9141). Then, when the problem occurs, try and figure out if the data network is even operational. Easiest is likely to connect a scanner and try to interrogate (live data) a module on the same network to see if you get anything.
Best of luck, keep us posted.
Speedy G (02-23-2023)
  #43
Old 02-23-2023, 01:19 PM
Received 8,323 Likes on 5,025 Posts
Sounds like a fault on the SERIAL DATA LINK network? (Fig. 21.1 of the electrical guide S2001_XK8.pdf)
  #44
Old 02-23-2023, 01:48 PM
Originally Posted by xalty
i guess they took the key add out of the thinkdiag poverty edition. my launch still has it has it 🤷‍♂️
Correct, it was not available in the recent version I bought.
  #45
Old 02-27-2023, 06:47 AM
Speedy G's Avatar
Going to order IDS this week what are they have a few different options which will be best choice
Baxter3319
01-17-2022 08:16 AM
Jetjock17
05-26-2021 08:11 PM
radjag1
06-27-2020 05:01 PM
ebrisec
05-18-2018 01:36 PM
Old_Doc
09-07-2014 09:42 AM
Quick Reply: Corrupted file in immobiliser next step
