courtesy door light drivers side{Left} door
have a 99 jaguar xk8 convertible and the drivers door courtesy light at the bottom will not come on. popped the lense and replaced the bulb and still nothing am wondering where the switch that tells it the door is open is located . was reading about a micro switch in the door latch assembly but from my understanding after reading that switch controls the window lowering 3/4 in. and reraising upon closing. this is functioning so that switch isnt the culprit. any ideas ?
thank jim .
thank jim .
Have a closer look and see figure 10.1 here: http://jagrepair.com/images/AutoRepa.../jagxk1999.pdf
The 'puddle lamps' are powered from the Driver door modules in the door, not the fusebox directly.
Doing some more work on the car today. Got all the side marker lights working tho one needs a good rap now and then to light up. Will have to check the socket or replace it if i can find it. Then the dreaded restricted performance code. Looked on the forum... connected the code scanner... and traced it to the knock sensor bank 2. Found the location for same on the forum and low and behold the connector at the thermostat tower was loose . (btw the knock sensors can be had for around 30 bucks if you look for them online) Anyhow looked down at the puddle lamp and its now working so evidently something was / is loose so if it fails again ill re try all the connectors and clean all or replace. Thanks to all for the help and insight. THE FORUM ROCKS .
My drivers window on my 2002 xk8 convertible returns to the top when the door is open, this makes closing the door a bit of an issue. When I lift the handle up it drops as it should. But as soon as i release the handle it returns to the top.. I have tried retraining the window but no success. I have since noticed the interior light doesnt come on when the door is open. It does when I switch it on..The passenger side works as it should. Im assuming its a faulty door sensor but I cant find it. Any ideas please. Thanks in advance.
If the lights really aren't coming on and if the you get a door ajar on the dash you can bet that it is the a micro switch in the door latch mechanism... They are not that hard to get out BUT (unless you have another car) I wouldn't start taking things apart until you have the CORRECT switches in hand and a good game plan aka pointers from folks here. It's fiddly business,,, them door switches.
https://www.ebay.com/itm/162778841458
