Crankshaft Pulley - How should it feel?
Thanks for looking. Yesterday I posted a thread about my car overheating and trying to determine if the belt was the cause. As per your excellent advice I removed the belt and turned each pulley by hand.
Something just occurred to me, I should have asked yesterday. The crankshaft pulley is not what I expected. It can be turned freely with no resistance and there is a spring feel to it in that it can be moved backwards towards the engine block a small amount against what feels like spring tension.
I wanted to check and verify that this is normal.
Thanks,
John
Thanks,
John
This is not normal. It sounds as if your crankshaft pulley broke loose. See this post on the issue: https://www.jaguarforums.com/forum/x...-remove-89379/ by Walt (may he RIP).
jimforrest (uk)
02-28-2019 06:42 PM
