Crankshaft sensor harness 1997 xk8
For the last couple of days I have been replacing the engine harness on an AJ26 1997 xk8.
I am finally down to the last three plugs on the harness.Two for the AC compressor which I can see and one for the cranck shaft sensor which I can not see.
There is a short harness that goes from the plug on the sensor itself and travels along the engine block and seems to end around or behind the AC compressor.
Need I loosen remove the compressor? Any other way of reaching the connector?
sweatyfox
02-10-2016 10:20 AM
FS[SouthEast]: 1984 Jaguar 4.2 engine with B/W trans.
Larry Louton
01-29-2016 08:32 PM
