cruise control for 1998 Jaguar xk8
Welcome to the forum Jack,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to XK8/XKR forum. Members here with the same model will be able to help.
I guess it all depends how much your car has fitted and how much it hasn't. If you have a 97 -98 throttle body, does it have the vacuum bellows fitted on top ? You will also need the steering wheel controls, centre console switch, vacuum control valves mounted under right hand side wing, maybe a replacement brake switch. Oh, and fingers crossed the ecu /body control modules are already cruise equipped which I guess they will. The wiring and pipe work should be easy enough, you will need the circuit schematics for the 97/98 car.
DeaconHull
08-28-2015 05:26 PM
