Cruise Control kaput
Do you have a check engine light? If so, have the codes read and post the actual numbers back here.
Your '99 XK8 cruise control is managed by the ECM and there are any number of OBDII codes that the first thing on the chart says that the CC is disabled.
I had an issue with the CC button on the center console that was causing an error message. A large number of operations of the switch seemed to clear it.
Camnelson324
09-27-2015 08:48 AM
zdrapec
09-25-2015 05:49 AM
