cruise control & washer problem
hello forum, 2001 xk8 no cruise and also washer fluid dosen't squirt onto headlights dosen't pop out either .... vacuum problem ???????? also is there a light to tell you when to change the oil on the 2001 xk8 or just keep track ????? thanks for your help...
When holding the wash function on for what seems like a long time trying to activate the headlamp washers are you seeing washer fluid dripping onto the ground up front? You didn't mention if the windshield washers are working? If you're getting puddles up front it's likely that the lamp washers are 'crudded'/stuck and no amount of vacuum is going to make them work without a little mechanical help getting the nozzles out where they work. I've used a dental pick to help pull washers free from two of my past cars with no damage or marks that corrected the problem.
Cruise control activation is likely electronic more than vacuum related. Someone with a bit more smarts than me about accessories will likely chime in and offer you a possible cure. Curious to see what the problem was as well as what the fix is. You've checked the fuses, right?
RB
RB
tony bosco (05-23-2014)
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
al_roethlisberger
09-11-2015 10:04 PM
