Which CTEK charger
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I know there has been threads on the ctec charger.I would like to buy one that comes with all the parts needed to leave it attached to the battery.so I only have to plug it in. there are a lot of them on ebay and amazon so any help would be accepted thanks
I have this model and am quite happy with it. (link contains picture of what comes in the box)
CT-56-864 - CTEK Multi US 4.3 12 Volt Charger
jrb53 (08-28-2014)
I have the same one and it's handy as it comes with a pug/terminal set that fits the Jag perfectly and can be brought up along the Battery cover joint to trunk floor level. I just open the trunk and connect it and use the other connector with the aligators for maintaining a generator battery.
I had a few electical hicupps before I got mine. No Oil pressure was one. Leaving your car sit for more than a couple of days can drop battery voltage below the threshold where the electonics work properly.
jrb53 (08-29-2014)
I have a CTEK 3600 and for the last couple of years have left it connected on "winter" setting when laid up (November - May) and have had no problems. My current battery (fitted by Jag dealer) is getting on for 5 years old now so will probably replace next year anyway. So my question is apart from the convenience of not having to reset windows/radio and heave the battery in and out is there any positive benefit for the car to leave battery connected while winter charging?
