Curb rash repair.
Old 10-15-2012 | 05:31 PM
Kevin D's Avatar
Default Curb rash repair.
I have spent quite a while searching, and can't find anything relevant to curb rash repair of my XK8 rims even though I recall seeing a thread about it some time back.
What I have been able to learn through searching is to be sure to use paint of the right color, which is obvious, but I simply cannot find any thread that directly references such a repair. Any help would be greatly appreciated. Thanks.
Old 10-15-2012 | 05:49 PM
itspec60's Avatar
I repaired the rash on my wheels using an epoxy puddy. First I sanded down the raised areas, washed the wheel and then used the puddy to fill the scratches. Sanded it smooth and filled more where necessary. The puddy I used was J-B STIK. You cut off a small piece and roll it in your hands to activate. I would suggest wearing disposable gloves when rolling it. My repair has been on for at least 1 1/2 years and no problems. The aluminum wheel has to be clean when you apply the puddy. I taped off the tire and did the repair and painting with the tire on the wheel.
Kevin D (10-15-2012)
Old 10-15-2012 | 06:43 PM
user 2029223's Avatar
Banned
Kev,
Do a search over in the XJ 100 series Forum. There were a few long running threads a year ago on the subject. I presume from your note you are interested in a DIY project.
Old 10-15-2012 | 06:51 PM
Here's a well documented and illustrated procedure that shows what can be repaired:
How to: Refurbish Alloy Wheels (detail and picture heavy) - MG-Rover.org Forums
So it's an MG. An alloy wheel is an alloy wheel!
The following 2 users liked this post by GGG:
Kevin D (10-15-2012), user 2029223 (10-19-2012)
hunter34
19
09-15-2022 12:09 AM
Dimitrigregorio
17
09-05-2019 04:47 AM
King Charles
04-16-2017 12:10 PM
mrplow58
09-15-2015 10:58 PM
Quick Reply: Curb rash repair.
