Damaged Convertible Top
I do a 303 application once per year and simply have my wife hold an old bath towel over the glass surfaces and painted surfaces as I move around the ragtop with the spray bottle. She stays just ahead of me with the bath towel. No masking required and if we take our time (maybe a total of six to eight minutes) and don't try to perform this application on a windy day, there is virtually no clean-up required afterwards....
wj
... If I don't see water getting in, I'll learn to live with the small hole that the spray washer bore into the fabric rather than spend the $1,900 for a replacement top.
But if anyone knows from experience that this is a bad idea, and that I should be replacing the top now, please let me know.
Even with a completely in-tact top, it's this rubber thingy that keeps the water out. The rayon layer on top of it does not.
So if the rubber is now exposed you're in a pretty vulnerable place. If it gets damaged and stops sealing, you'l be forced into getting a new top.
llucky,
This thread is a little old, but if you still have stripes on your top, it's possible that you could reduce the visibility of the "fuzzy" part by careful use of a heatgun. I've used this technique to make worn webbing look much nicer. This only works with synthetic fibers and you have be very judicious with the heat, but it might give your top a reprieve.
Mike
Mike
My cleaning and my spraying of the top with protectant did not remove the doodles in the fabric from the car wash sprayers, but has improved the water repellency of the canvas.
That said, as has been noted, the top's water repellency is ultimately secured by the rubber membrane beneath the canvas, not by the repellency of the canvas itself.
I have not noticed any water getting through the top, despite of the hole bore through the canvas by the car wash sprayers.
To provide additional protection to the membrane, I have glued a canvas patch on the membrane where the hole was bore through the original Twillfast canvas.
My 1999 top is getting worn in several places and I will likely replace it altogether next spring, but for now, I'll defer that $1,900 cost.
Unless you are close up, the top doodles are not that noticeable.
